Up until today we were using Infragistics 12.1 for our Data charts, today I upgraded to 16.2.
The problem is that the Legend data point format radically changed from a nicely styled square to a circle with a glaring magenta border that is awful.
I went back to our 12.1 version and grabbed the style for the legend as a copy. That style does not seem to affect the data point style.
My superiors are not amused and want the old format. HELP!
Thanks in advance,
Kenn
Key360 and all who are having issues with the change in Legend formats from 12.1 to more recent releases.
The OldStyle.zip included with this Infragistics response fixed my problem with the legend data points.
I used the legacy style that was included.
https://ko.infragistics.com/community/forums/t/94197.aspx
Key360,
That solved the ugly outline problem, now I just need to get my Legend data points back to nice styled rectangles instead of boring circles.
Thanks for your help!
Best Regards,
Had the same problem.
you should set both the Brush property and the Outline property of the series to the same brush to get a solid color.
Hello Kenn,
Thank you for contacting Infragistics. Could you please provide a screenshot/mockup of the behavior? Also, are you using any themes or custom styles to retemplate the Legend? If you could provide a sample project demosntrating the behavior I will be able to provide an adequate solution quicker.
