I am monitoring temperature and I want to display the last 24 hours. I need the x axis to look like this:
-24 -18 -12 -6 0 -The label intervals aren't really important.
But because the datapoints are every minute, there will be 1440 data points or intervals on the x axis.
But I can't change the labels into minus hours rather than minus minutes.
I wrote this out once with a lot more detail but I lost it when I clicked post so I''m keeping this one short.
Marc
Ok, I'll give it a go.
Thanks Rob.
Hi Marc,
You should be able to specify a DataTemplate for the X axis Label property and then configure the label text however required. Probably converting the minutes into hours.https://ko.infragistics.com/help/wpf/datachart-axis-label-templates
There is also an Interval property that you can set which should let you control the frequency of the labels.
