1385
Putting helper text in the add row cells
I would like the add row to have some gray helper text like <Type a label>.  It would only appear in the add row, and would only appear if the cell is empty.  How can that be done?
Parents
  • 29105
    Hello Walter,
    Thank you for contacting Infragistics. You can use a conditional MultDataTrigger for each field accordingly. This topic was previously discussed and answered here: Text in Add New Record Row
    eg.
      <igDP:FieldLayout.Fields>
                            <igDP:Field Name="Name" >
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings >
                                        <igDP:FieldSettings.EditorStyle >
                                            <Style TargetType="{x:Type igEditors:XamTextEditor}">
                                                <Style.Triggers>
                                                    <MultiDataTrigger>
                                                        <MultiDataTrigger.Conditions >
                                                            <Condition Binding="{Binding RelativeSource={RelativeSource Mode=Self}, Path=Text}" Value="" />
                                                            <Condition Binding="{Binding RelativeSource={RelativeSource Mode=FindAncestor, AncestorType={x:Type igDP:DataRecordPresenter}}, Path=IsAddRecord}"  Value="True" />
                                                        </MultiDataTrigger.Conditions>
                                                        <MultiDataTrigger.Setters>
                                                            <Setter Property="NullText" Value="Add name" />
                                                            <Setter Property="FontStyle" Value="Italic" />
                                                            <Setter Property="Opacity" Value="0.4" />
                                                        </MultiDataTrigger.Setters>
                                                    </MultiDataTrigger>
                                                </Style.Triggers>
                                            </Style>
                                        </igDP:FieldSettings.EditorStyle>
                                    </igDP:FieldSettings>
                                </igDP:Field.Settings>
                            </igDP:Field>
    https://ko.infragistics.com/community/forums/p/53736/277938.aspx#277938
Reply Children
No Data
