920
Show combobox inside the grid using MVVM
   My question is similar to the question on this thread https://ko.infragistics.com/community/forums/t/34846.aspx.
I studied the sample code sample download from the thread and applied it to my solution with changes to obsoleted segments and I cant get it to work. The comboboxes are not showing up. Please help.
Here is my code
<igDP:Field BindingType="UseAlternateBinding" AlternateBinding="{Binding Path=SelectedCity, Mode=TwoWay}" Label="{x:Static localization:ManagerParameters.ModificationLabel}" Visibility="Visible">
<igDP:Field.Settings>
<igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}">
<igDP:FieldSettings.EditorStyle>
<Style TargetType="{x:Type igEditors:XamComboEditor}">
<Setter Property="ItemsSource" Value="{Binding DataPresenter.DataContext.Cities}"/>
</Style>
</igDP:FieldSettings.EditorStyle>
</igDP:FieldSettings>
</igDP:Field.Settings>
</igDP:Field>
Lala
