1385
OverflowException occurs in localized XamSpreadsheet
I'm using v16.2.20162.2045 and getting an OverflowException when using the XamSpreadsheet and a locale. In this particular example, I am setting cells to a Double value with decimals like 3.1415926535.  The Workbook.Culture behind the scenes is set to Persian (Iran).
When the spreadsheet is displayed, the numbers are shown in their native characters.  When a cell is double clicked, it goes into edit mode and shows what looks like a fraction in English numerals (1/2343135423).  When the cell loses focus, the exception occurs.
Any ideas?
System.OverflowException occurred
HResult=-2146233066
Message=Value was either too large or too small for an Int32.
Source=mscorlib
StackTrace:
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at Infragistics.Controls.Grids.Core.SpreadsheetEditHelper.TryParseFraction(String text, Boolean mustHaveLeadingDecimal, IFormatProvider formatProvider, Double& value, Int32& preferredFormatIndex, Boolean& hasLargePostIntegerSpace)
at Infragistics.Controls.Grids.Core.SpreadsheetEditHelper.GetNewValue(ISpreadsheetEditInfo info, ISpreadsheetEditorValue value, Boolean createArrayFormula, Boolean useTextForInvalidFormulas, Int32& preferredFormatIndex)
at Infragistics.Controls.Grids.Core.SpreadsheetEditHelper.UpdateCells(SpreadsheetCellExitModeAction exitAction, ISpreadsheetEditorValue editValue, Boolean canStayInEditMode, String unformattedText, Boolean wasVisitedHyperlinkCell)
at Infragistics.Controls.Grids.Core.SpreadsheetCellEditManager.ExitEditMode(SpreadsheetCellExitModeAction action, Boolean mustExitEditMode, Boolean focusControl)
at Infragistics.Controls.Grids.Core.SpreadsheetCellEditManager.EndEdit(SpreadsheetCellExitModeAction action, Boolean force, Boolean returnFalseOnValidationFailure, Boolean focusControl)
at Infragistics.Controls.Grids.Core.Spreadsheet.TryExitEditMode(Boolean acceptChanges)
at Infragistics.Controls.Grids.Core.SpreadsheetInteractionManager`1.OnMouseDown(InputProxy proxy)
at Infragistics.Controls.Grids.Primitives.SpreadsheetElementLayerContainer`1.OnMouseDown(MouseButtonEventArgs e)
at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Window.ShowHelper(Object booleanBox)
at System.Windows.Window.ShowDialog()
