We're using a Xamdatagrid and storing our customization XML in a database for persistence. We have "AllowFixing" set to "Near" on our xamdatagrid.FieldSettings. When a user pins a column, the column is moved to the front, as expected, the pin widget appears pinned, and the appropriate separator bar appears between the pinned column and all of the other columns.
When the user restarts the application and reloads their data, however, the pin widget appears unpinned and the separator bar is gone. The underlying customization XML is intact and contains a FixedLocation="FixedToNearEdge" attribute. The column itself remains in the pinned location on the grid, it is simply no longer pinned. What additional steps do we need to take to make sure we can persist pinned columns? How do we set the pin widget to "pinned"?
Hello Nat,
Thank you for your feedback. Let me know if you need any further assistance.
Sincerely,ZhivkoAssociate Software Developer
Thank you for your help, Zhivko. I'll take this higher up my management chain to see if we can update our licenses to the latest supported version.
Cheers,
Nat
Hello Nad,
I just want to add a suggestion to test your sample application with the latest Service Release of 12.2, just in case if it has been an issue that is fixed in the latest Service Release.
Since version 12.2 is no longer supported(please see the Product Lifecycle page) the best I can suggest is to download and test your application with the latest Service Release of version 16.2.
If you are able to reproduce the same issue for FixedFields with version 16.2, the best for us would be to provide a small isolated sample(or modify our project) and send back to us, this way we will can run and use for debugging locally. If you are unable, able to provide an isolated sample we may be able to give suggestions if you provide the code that you are using.
Much appreciated! I'll take a look at this solution this morning.
A cursory investigation reveals that my organization appears to be on Infragistics 12.2. We're building against the latest .NET framework. This issue is present on all of our machines, which run a wide range of specifications, from low end to high end. Both Windows 7 and Windows 10.
