1865
Bind XamComboEditor to ObservableCollection?
I am using MVVM. My VM has two properties (1) [Data] which returns ObservableCollection<Account> and (2) [AccountAttributes] which returns ObservableCollection<AccountAttribute>.
I View's code behind DataContext set to above class. [Data] is bound to xamDataGrid and it works fine. I want to bind an property in [AccountAttributes] to XamComboEditor which is linked to a column in xamDataGrid. What is the exact syntax in XAML? If I change [AccountAttributes] to List<string> it works fine but want it to be an ObservableCollection.
Thanks.
