100
Intercept Field from MenuItem
Hi.
In a Xamdatagrid I added a menuitem in HeaderLabelArea from the Code behind. This is code:
Dim MyMenuitem As New MenuItem
MyMenuitem.Header = "Move to first"
AddHandler MyMenuitem.Click, AddressOf Me.MenuItem_Click
Dim MyContextMenu As New ContextMenu
MyContextMenu.Items.Add(MyMenuitem)
MyMenuitem.CommandParameter = MyContextMenu
Dim MyStyleForHeaderLabel As New Style(GetType(HeaderLabelArea))
MyStyleForHeaderLabel.Setters.Add(New Setter(ContextMenuProperty, MyContextMenu))
MyXamdatagrid.FieldLayoutSettings.HeaderLabelAreaStyle = MyStyleForHeaderLabel
But now I can not intercept what column the menuitem has been opened so that I can do the operation
Can you help me.
Thank you so much
  • 16495
    Verified Answer
    Hello Francesco,
    You can add the ContextMenu to LabelPreseter instead of HeaderLabelArea. This way you will be able to use ContextMenu's PlacementTarget property, which returns the UIElement relative to which the menu is positioned when it was clicked, for example:
    Dim MyStyleForHeaderLabel As New Style(GetType(LabelPresenter))
    MyXamdatagrid.FieldSettings.LabelPresenterStyle= MyStyleForHeaderLabel
    Private Sub MyMenuitem_Click(sender As Object, e As RoutedEventArgs)
     Dim lbl As LabelPresenter= TryCast(TryCast(e.OriginalSource, MenuItem).Parent, ContextMenu).PlacementTarget as LabelPresenter
    End Sub
    Sincerely,
    Zhivko
    Associate Software Developer
