95
Exception: Cannot modify the logical children for this node at this time because a tree walk is in progress.
The following exception was reported to me by a customer using the software I developed using the Infragistics WPF controls in version 16.1.20161.1000. I have no information what the user was doing, and I cannot reproduce the exception. I only know it occurred when entering data into a WPF data grid, and happened within an OnValueChanged event based on this code:
EventManager.RegisterClassHandler(typeof(ValueEditor), ValueEditor.ValueChangedEvent, new RoutedPropertyChangedEventHandler<object>(OnValueChanged));
void OnValueChanged(object sender, RoutedPropertyChangedEventArgs<object> e)
    if (sender is Infragistics.Windows.Editors.XamComboEditor || sender is XamDateTimeEditor || sender is XamCheckEditor || sender is TemplateEditor)
        if (sender is Infragistics.Windows.Editors.XamComboEditor)
            if ((sender as Infragistics.Windows.Editors.XamComboEditor).IsEditable) return;
        (sender as ValueEditor).EndEditMode(true, true);
(Not my code, I inherited the project from a colleague who left the company)
I found these posts with the same error message, but the first on is from 2011 and marked as fixed, and the second one suggest surrounding everything with a try / catch block (which I could do, nut I would prefer to find the actual problem)
https://ko.infragistics.com/community/forums/t/60351.aspx
https://ko.infragistics.com/community/forums/t/92148.aspx
Without being able to reproduce the problem I have little hope to find a solution, but maybe someone has had the same problem before and has any idea on what might have gone wrong.
Hannes
System.InvalidOperationException    Cannot modify the logical children for this node at this time because a tree walk is in progress.
at System.Windows.FrameworkElement.RemoveLogicalChild(Object child)
   at Infragistics.Windows.Controls.PopupResizerDecorator.MeasureOverride(Size constraint)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at Infragistics.Windows.Controls.ClippedTextToolTipService.IsToolTipNeeded(TextBlock tb)
   at Infragistics.Windows.Controls.ClippedTextToolTipService.OnFindToolTip(Object sender, RoutedEventArgs e)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.Controls.PopupControlService.LocateNearestToolTip(DependencyObject& o)
   at System.Windows.Controls.PopupControlService.InspectElementForToolTip(DependencyObject o)
   at System.Windows.Controls.PopupControlService.OnMouseMove(IInputElement directlyOver, Point pt)
   at System.Windows.Controls.PopupControlService.OnPostProcessInput(Object sender, ProcessInputEventArgs e)
   at System.Windows.Input.InputManager.RaiseProcessInputEventHandlers(ProcessInputEventHandler postProcessInput, ProcessInputEventArgs processInputEventArgs)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.MouseDevice.Synchronize()
   at System.Windows.Controls.Primitives.Track.OnIsEnabledChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.PropertyChangedCallback.Invoke(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
   at System.Windows.StyleHelper.InvalidatePropertiesOnTemplateNode(DependencyObject container, FrameworkObject child, Int32 childIndex, FrugalStructList`1& childRecordFromChildIndex, Boolean isDetach, FrameworkElementFactory templateRoot)
   at System.Windows.StyleHelper.ClearTemplateChain(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, List`1 templateChain, FrameworkTemplate oldFrameworkTemplate)
   at System.Windows.StyleHelper.ClearGeneratedSubTree(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, FrameworkTemplate oldFrameworkTemplate)
   at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate)
   at System.Windows.Controls.Control.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents)
   at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle)
   at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache)
   at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.UpdateStyleProperty()
   at System.Windows.TreeWalkHelper.InvalidateStyleAndReferences(DependencyObject d, ResourcesChangeInfo info, Boolean containsTypeOfKey)
   at System.Windows.TreeWalkHelper.OnResourcesChanged(DependencyObject d, ResourcesChangeInfo info, Boolean raiseResourceChangedEvent)
   at System.Windows.FrameworkElement.OnAncestorChangedInternal(TreeChangeInfo parentTreeState)
   at System.Windows.TreeWalkHelper.OnAncestorChanged(DependencyObject d, TreeChangeInfo info, Boolean visitedViaVisualTree)
   at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree)
   at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree)
   at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren)
   at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren)
   at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d)
   at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode)
   at MS.Internal.PrePostDescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode)
   at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation)
   at System.Windows.FrameworkElement.OnVisualParentChanged(DependencyObject oldParent)
   at System.Windows.Media.Visual.FireOnVisualParentChanged(DependencyObject oldParent)
   at System.Windows.Media.Visual.RemoveVisualChild(Visual child)
   at System.Windows.FrameworkElement.set_TemplateChild(UIElement value)
   at Infragistics.Windows.Editors.ValueEditor.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.Editors.TextEditorBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.Editors.XamComboEditor.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.CoerceValue(DependencyProperty dp)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at Infragistics.Windows.Editors.ValueEditor.EndEditMode(Boolean acceptChanges, Boolean force)
   at Client.App.OnValueChanged(Object sender, RoutedPropertyChangedEventArgs`1 e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at Infragistics.Windows.Editors.ValueEditor.RaiseEventHelper(RoutedEventArgs args)
   at Infragistics.Windows.Editors.ValueEditor.EndSyncValueProperties()
   at Infragistics.Windows.Editors.XamComboEditor.OnValueChanged_SyncProperties(ValueChangeSource source, Object value, Boolean calledFromSyncValuePropertiesOverride)
   at Infragistics.Windows.Editors.XamComboEditor.OnComboBox_SelectionChanged(Object sender, SelectionChangedEventArgs e)
   at System.Windows.Controls.ComboBox.OnSelectionChanged(SelectionChangedEventArgs e)
   at System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
   at System.Windows.Controls.Primitives.Selector.SelectionChanger.SelectJustThisItem(ItemInfo info, Boolean assumeInItemsCollection)
   at System.Windows.Controls.ComboBox.NotifyComboBoxItemMouseUp(ComboBoxItem comboBoxItem)
   at System.Windows.Controls.ComboBoxItem.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
  • 34810
    Hello hannes565,
    I have been investigating into this exception message that you are reporting, and it appears that this scenario is a bit different from the two forum threads that you have provided. As such, I doubt those will really be of much help. I have gone through our bug archives, but I cannot say that I was able to find an issue matching this one, and as such, I believe we will require some more information from your end to reproduce this issue before we can really act on it.
    You have included a handler for what appears to be the ValueChanged event for any ValueEditor derivations, and I am assuming that this issue is appearing when making a call to this line:
    If this is not the case, please let me know, as I have put together a sample project that I have tested against both the latest version of our 2016.1 WPF product (16.1.20161.2231) and the base version that you are using (16.1.20161.1000). I was unable to reproduce this behavior with both. It also appears that the only way your EndEditMode invocation would be called is if the ValueChanged event was raised by a XamComboEditor with its IsEditable property set to false. As such, I have followed that guideline in the sample project.
    I have attached the sample project that I have used to test this. I would like you to review it, and perhaps make some changes to it such that this issue is reproducible. If the sample project does not accurately reflect what you are trying to do, I encourage you to modify it or perhaps provide an isolated sample project of your own where this is reproducible. Any additional information about your scenario or steps to possibly reproduce this issue may be helpful as well.
    Sincerely,
    Andrew
    Associate Developer
    XDGValueEditorExceptionTest.zip
