535
Suppress automatic reevaluate filters on data change
Hi there,
I’m facing right now a strange behavior when I want to suppress the automatic reevaluate and filtering of my data in my xamDataGrid.
My goal is that I when I set a filter in my xamDataGrid the filtered elements remain the same, even when I change the values and even if the new value violates my filtering-rule. To achieve this I set the FieldLayoutSettings attribute ReevaluateFiltersOnDataChange and ReevaluateFiltersOnRecordsAdded to false on any relevant xamDataGrid.
Strangely in some DataGrids it works like a charm and other DataGrids totally ignore this setting. Sadly I can’t create an example, because as soon I try to make a sample project everything works just fine. But in general I have mostly the same Settings in every DataGrid (copy&paste ftw).
Another strange behavior is this that in some DataGrid this functionality was already given but not by implementing the above mentioned attributes, just by accident I had this behavior.
In general I use “complex” objects for the columns, so mostly I have some kind of wrapper object I bind to the UnboundField. But it doesn’t really matters because some other time I use just string properties.
Sometimes I use AutoGenerateFields true and sometimes not, but in both cases I can observe the problem. I often have to extend the .xaml.cs file to archive my wanted experience but I never really did anything which include the filter-behavior.
I understand that you probably can’t really help me without a reproducible sample project but at this point I only hope you have some general direction you can point me. Maybe because you know some constellation where the reevaluate can be tricked or overridden.
The only sample project I could create is to show the opposite effect. I activated the attributes but when I filter for a specific year in my grid and change the year after the filtering, then the row will still be displayed.
For example I filter for the year 2014 and only one row will be shown, then I change the year of that row to 2015 the row will be still be displayed but in the ToolTip of the filter It’s say ‘=2014”.
The used FieldLayoutSettings in the example is mostly my standard settings I use in every DataGrid and almost every other Grid is build this way.
BR
Andreas Hensel
20170825_FilterProblem.zip
