1435
ButtonTool property can't find an image
I have a solution with many projects. The RibbonTabItem control is defined in project X. This control is used in project Y.
<<igRibbon:RibbonTabItem>
     <igRibbon:RibbonGroup>
             <igRibbon:ButtonTool  />
     </igRibbon:RibbonGroup>
</igRibbon:RibbonTabItem>
Each project has its own resource images stored in a folder within the project itself.
The ButtonTool LargeImage property in the Markup is "/X;component/Images/Plus.png"
I'm getting a run time error : image not found.
If I place a copy of the image in project Y, the image appears and all good. (designer error = none, run time errors = none)
If I remove the image from project X and leave it project Y, I get a designer error and no run time error.
Somehow the ButtonTool is not respecting the image path and looking for it in assembly Y even though it is instructed to look for it in the assembly X.
I have consulted the microsoft web on Pack URIs in MarkUp and tried LargeImage="pack://application:,,,/Plus.png"
Please note that MaximumSize property is set to ImageAndTextLarge..
Thank you
