Is is possible to use xamDataTree control instead of list to select items?
It should look something like that:
Is there easy way to achieve this kind of control?
Jarek
Hello Jarek,
Thank you for your feedback.
If you have any questions, please let me know.
Thanks for the answere
In order to display a XamDataTree inside the dropdown of the combo editor, I can suggest you retemplate the control by using its default style and implement the necessary logic for the synchronization between the controls.
Having a XamDataTree as the content of the combo editor's dropdown has been determined to be a product idea. You can suggest new product ideas for future versions by emailing ideas@infragistics.com.
Submitting your idea will send it directly to our product management team so that it can be imported into our new ideas community once live: http://ideas.infragistics.com.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
