240
Can't exit from edit mode if Key of the column is read only
Hi
I have problems when exiting from edit mode. I need to use filtering using a menu and I set the key property of the column to read-only property, the property will be updated in control which defined in the template.
I attached an example to good understanding of my problem. I didn't add the custom control in the template because this issue also appears in more simple way :)
Do you know how can i handle this?
ReadOnlyKeyBinding.zip
