var html = "<body>
<p id = "Example">
<span>
<font>aaaaa</font>
</p>
<body>"
I use XamRichTextEditor and HtmlDocumentAdapter,
HtmlDocumentAdapter.value = html, then XamRichTextEditor will show this html content,
when I select "aaaaa",can I use some methods to get this node's parent, such as <p>'s id(Example).
Thank you.
The ability to get HTML nodes in XamRichTextEditor when HtmlDocumentAdapter is used has been determined to be a product idea. You can suggest new product ideas for future versions by emailing ideas@infragistics.com.
Submitting your idea will send it directly to our product management team so that it can be imported into our new ideas community once live: http://ideas.infragistics.com.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
