3220
xamDataTree DragOver event
in my DataTree control I just want to allow special nodes to be drag & drop able. Therefore I would need a DragOver event to determine if a Drop operation is allowed on a hovered node. Corrently there is no such an event.
As read from a different thread, I could use the Drag & Drop Framework, but then I would loose the build in functionality of that tree control. e.g. No scrolling, no line indicator where to drop.
https://ko.infragistics.com/community/forums/p/57497/293250.aspx#293250
Is there a workaround to achiev that goal?
  • 2180
    Hello Markus,
    After investigating the current implementation of the drag/drop functionality of the xamDataTree control and DragOver event in the framework, implementation of this event has been determined to be a product idea. You can suggest new product ideas for future versions by emailing ideas@infragistics.com.
    Submitting your idea will send it directly to our product management team so that it can be imported into our new ideas community once live: http://ideas.infragistics.com.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea.
