255
WPF- Not able to Bind XamDatagrid with observable collection
i am  trying to bind  xamdatagrid to the observable collection.
<Grid>
<ItemsControl x:Name="MyItemContol" ItemsSource="{Binding ViewSetList}" VerticalAlignment="Stretch" HorizontalAlignment="Stretch">
<ItemsControl.ItemTemplate>
 <DataTemplate>
 <igDP:XamDataGrid DataSource="{Binding ViewSetList}" >
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
 <igDP:Field Name="PARAMETER">
<igDP:Field.Settings>
<igDP:FieldSettings AllowEdit="False" />
</igDP:Field.Settings>
</igDP:Field>
 <igDP:Field Name="VALUE">
</igDP:Field> <igDP:Field Name="UNIT">
 </igDP:Field>
<igDP:Field Name="INSTANCE">
</igDP:Field>
 </igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
 </igDP:XamDataGrid>
 </DataTemplate>
</ItemsControl.ItemTemplate>
</ItemsControl>
</Grid>
and my cs file will look like this
public partial class MainWindow : Window
           private ObservableCollection<Parameters> viewSetList = new ObservableCollection<Parameters>();
           public MainWindow()
                InitializeComponent();
                viewSetList.Add(new Parameters() { PARAMETER="abc", INSTANCE="def" , UNIT="hhshhd", VALUE="hahha" });
           public ObservableCollection<Parameters> ViewSetList
          get { return viewSetList; }
          set
              viewSetList = value;
public class Parameters: INotifyPropertyChanged
private string parameterName = string.Empty;
public string PARAMETER
get { return parameterName; }
set { parameterName = value; }
private string parameterValue = string.Empty;
public string VALUE
get { return parameterValue; }
set { parameterValue = value; }
private string parameterUnit = string.Empty;
public string UNIT
get { return parameterUnit; }
set { parameterUnit = value; }
private string instance = string.Empty;
public string INSTANCE
get { return instance; }
set { instance = value; }
public event PropertyChangedEventHandler PropertyChanged;
private void onPropertyChanged(object sender, string propertyName)
if (this.PropertyChanged != null)
PropertyChanged(sender, new PropertyChangedEventArgs(propertyName));
