I can't find the xamSegmentedDisplay in v17.2!
It was still available in v17.1, has it been removed?
Daniel Secci
Hi Brian,
we used it to display the current time. We really liked the style of this component.
We will integrate 17.1 for this component and use 17.2 for the rest until you integrate it again or we find another one...
Daniel
Yes, it has been removed as it was part of our very old and outdated gauges assembly. You can red about the announcement here:
https://ko.infragistics.com/community/blogs/blagunas/archive/2017/11/14/infragistics-ui-for-wpf-17-2-control-retirements.aspx
Is the segmented control of high value to you? Our usage numbers on it are very low, so if you require this control, it would be good to know. If we get enough requests, we will write a new one.
