I'm registering some custom simple formulas using workbook.RegisterUserDefinedFunction(formula). The workbook is then saved (in Excel2007 format). When the workbook is loaded again as a new workbook and the formulas registered on that workbook the formulas aren't connected/active. They do become active when individually reapplied to each of the cells they are used in but this is nasty and problematic. I can imagine that not having foreknowledge of the formulas during loading might result in this behaviour but it's really not very useful. So the question is: how can I register the user defined formulas so that they are active when the workbook is loaded? (using 17.1)
Great, thanks Kiryu
Hi Stephen,
Thank you for your patience.
This issue has already been fixed internally and will be included in the next service release. I have created a private case and linked this case to Development Issue 245185 so that you will be notified when the service release is available. You can see the service release schedule here:
http://ko.infragistics.com/support/service-releases
Best regards,Tatsushi KiryuDeveloper support EngineerInfragistics
Thank you for contacting Infragistics Developer Support.
I am currently working on this and will update once I have more information.
Best regards,
