I have several charts which use a CategoryDateTimeXAxis to display historical and forecast sales data. I would like to place a marker (such as a red vertical line) on these charts to indicate the current date (and hence the boundary between historical data and forecast data). I think I should be able to do this using a CrosshairLayer with a fixed CursorPosition - however, I can't see how to calculate the cursor position that is equivalent to a particular date. Any suggestions?
Yes, that's done the trick nicely. Thanks again.
Oh, that's strange - now I can reply using my own account... Very odd. Anyway, I'm suddenly busy with a bunch of other stuff, but will hopefully have time to verify this solution at some point this week.
Thanks Andrew, that looks like exactly what I'm looking for...
(I no longer seem to be able to reply using my own account, unfortunately... Something to do with the forum redesign that seems to have just happened.)
Hello Gregorach,
Rather than utilizing the CrosshairLayer with a fixed CursorPosition, I would recommend utilizing the ValueOverlay in the XamDataChart. This allows you to draw a vertical or horizontal line at a point of your choosing in the chart, and you can read about use of ValueOverlays here: https://ko.infragistics.com/help/wpf/datachart-series-value-overlay.
In this case, you would define a ValueOverlay and point its Axis property at your CategoryDateTimeXAxis as this will designate that you want a vertical line. The Value in this case would be the Ticks of DateTime.Today, and so I would recommend that you define a DateTime property on your view model that is set to DateTime.Today and bind the Value of the ValueOverlay to <propertyName>.Ticks.
I have attached a sample project to demonstrate the above. I hope this helps.
Sincerely,AndrewAssociate Developer
