Good day to all!I need to create a production calendar.That is, highlight weekends any color.The last two days I tried various options, but I did not find any working solution. As it seems to me, such functionality for the calendar should be standard, but for some reason there is very little information about it.
Thank you for your reply.I will write in the section of ideas!
But I need to solve the problem in the shortest time, so I'm trying to find a solution now.I found here two different options, but none of them came up to me or worked.Here's what I found:
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/67378/how-to-set-a-special-color-to-an-important-day-in-xamcalendar
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/74325/set-backgroundcolor-to-specific-dates
But both of these options are not undermined, or I just do not understand how to use them.If you can give me any idea of a working solution, I would be very grateful to you.
Hello Nikolay,
Thank you for contacting Infragistics. The XamCalendar has but a few "look and feel" properties. One of which is the CalendarDayStyle which can override a single CalendarDay and not for repeating workweeks and weekends. You may find some help on this forum that mentions using a converter to control which days get styled.
I also recommend submitting a new product idea.
You can suggest new product ideas for future versions (or vote for existing ones) at <https://ko.infragistics.com/community/ideas>.
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
