475
XamGrid Row Selection
Hi!
Is there a way to select a row in the XamGrid matching the keyboard entry to the value of a certain column?
Example my XamGrid has the following:
Name      Age
Erika        20
Fder        23
Rich        24
Edmar    25
Say I chose the 'Name' column...if I type in 'Ri' it will highlight the 3rd row, which is Rich. Then if I typed in 'E' it will go to the first row -- Erika. It will be like how it is when listing folders and files in Windows where it highlights the first instance with the letters being typed (matched by folder or file name).
Thanks!
  • 20
    Hello Erika,
    I suggestion that using ScrollCellIntoView and SelectedRows.
    I created a simple sample application.
    In the sample, there are textbox.If you input text,the corresponding line is selected from name column.
    IEnumerable<Row> result = xamGrid.Rows.Where(row => ((Person)row.Data).Name.Contains(xamText.Text));
    if(result.Count() > 0)
        xamGrid.SelectionSettings.SelectedRows.Clear();
        foreach (Row row in result.ToArray())
            xamGrid.SelectionSettings.SelectedRows.Add(row);
        xamGrid.ScrollCellIntoView(result.ToArray()[0].Cells[0]);
    I hope this will help.
    6138.Sample.zip
    Best Regards
