In the attached screenshot text Velocity is shown as Velo... while Market Making is display as is.
What determines when to apply an ellipse to the text value?
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/120715/get-the-handle-of-marker-inside-scatter-series
can u please have a look and help me out to resolve the issue
Hello Michael,
Versioned NuGet packages are no longer provided by the Infragistics for WPF product. This was discontinued in version 2016.2 when we began consideration of an online licensed NuGet feed. To keep the names of the NuGet packages consistent between the online NuGet feed and the offline ones for the purposes of making upgrading much simpler, we discontinued the versioned NuGet packages.
For more information about the online NuGet feed, I would recommend seeing the following article.
Hi Michael,
We are still in the process of upgrading to 18.1, in the past we would would receive 2 NuGet archive packages, 1 with version # and the other version free, now are only get NuGet version free package. Do you know why this is the case? We have a support case open requesting this CAS-197834-Y7J9C7.
We are requesting the NuGet packages with the version #.
Michael
I just wanted to follow up that we addressed the issue. However, as seen in the sample, I attached, "Market Making" now always appears as "Market Ma..." no matter what zoom level. It will never show entirely as before because it cannot actually fit. We adjusted the internal collision detection so it applies to ever label respectfully. This should address the inconsistency you've encountered and you will start seeing ellipsis when applicable. Let me know if you have any questions.
Thank you Michael for your effort, I have a valid Infragistics license, I am planning to download and upgrade in the next few days.
