2395
XamlParseException in 15.1 assemblies
We are occasionally getting a XamlParseException when opening a window with XamDataGrid. it's intermittent, so I can't provide a sample that shows the behavior. Were there any bug fixes for XamlParseExceptions in Infragistics WPF versions after 15.1? Stack trace is below:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Xaml.XamlParseException: Exception of type 'System.Xaml.XamlParseException' was thrown.
   at System.Windows.Baml2006.Baml2006Reader.ReadObject(KeyRecord record)
   at System.Windows.ResourceDictionary.CreateObject(KeyRecord key)
   at System.Windows.ResourceDictionary.OnGettingValue(Object key, Object& value, Boolean& canCache)
   at System.Windows.ResourceDictionary.OnGettingValuePrivate(Object key, Object& value, Boolean& canCache)
   at System.Windows.ResourceDictionary.GetValueWithoutLock(Object key, Boolean& canCache)
   at System.Windows.ResourceDictionary.GetValue(Object key, Boolean& canCache)
   at System.Windows.FrameworkElement.FindResourceInternal(FrameworkElement fe, FrameworkContentElement fce, DependencyProperty dp, Object resourceKey, Object unlinkedParent, Boolean allowDeferredResourceReference, Boolean mustReturnDeferredResourceReference, DependencyObject boundaryElement, Boolean isImplicitStyleLookup, Object& source)
   at System.Windows.FrameworkElement.FindImplicitStyleResource(FrameworkElement fe, Object resourceKey, Object& source)
   at System.Windows.FrameworkElement.GetRawValue(DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry& entry)
   at System.Windows.FrameworkElement.EvaluateBaseValueCore(DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry& newEntry)
   at System.Windows.DependencyObject.EvaluateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry newEntry, OperationType operationType)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.ClearValueCommon(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata)
   at Infragistics.Windows.DataPresenter.RecordPresenter.InitializeVersionInfo()
   at Infragistics.Windows.DataPresenter.RecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.DataRecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
   at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
   at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
   at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange)
   at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange)
   at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange)
   at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
   at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
   at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
   at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
   at Infragistics.Windows.DataPresenter.FieldLayout.InvalidateGeneratedStyles(Boolean bumpVersion, Boolean regenerateTemplates, Boolean bumpSpecialRecords, Nullable`1 clearAutoFitState)
   at Infragistics.Windows.DataPresenter.FieldLayoutCollection.InvalidateGeneratedStyles(Boolean bumpVersion, Boolean regenerateTemplates, Boolean bumpSpecialRecords, Nullable`1 clearAutoFitState)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.InvalidateGeneratedStyles(Boolean bumpVersion, Boolean clearGroupBy, Boolean regenerateTemplates)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.OnInvalidateGeneratedStyles()
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
  • 7555
    Hello Dierk,
    Thank you for posting. We reviewed existing bugs to see if we could find one with the same call stack and didn't find any. To look into what is happening we need a sample that reproduces the issue that we can use for debugging. You can also see if upgrading to the latest volume changes the behavior.
    Also, I would like to know if you are doing any threading and updating the grid or its datasource on a background thread that may be relevant information. Do you have the grid on the window that is being opened and if so, how is that window opened.
    Please provide more information in order to find the cause of the issue.
    Looking forward to hear you back.
