20
BindingExpression path error with XamRibbon Application Menu 2010
I am using the XamRibbon with an Application Menu 2010 with the Office 2013 theme. When opening the Backstage, the following error appears in the output:
System.Windows.Data Error: 40 : BindingExpression path error: 'ChildDesiredWidth' property not found on 'object' ''Button' (Name='BackButton')'. BindingExpression:Path=ChildDesiredWidth; DataItem='Button' (Name='BackButton'); target element is 'ColumnDefinition' (HashCode=3061223); target property is 'MinWidth' (type 'Double')
Is this an issue where I have missed something or have a problem in the implementation? I have tried both 2018.1 and 2018.2 versions and I can see this issue on both.
Aaron
