125
XamDataGrid Change Column Header
How can I programmatically change the column header similar to this code:
grid.Columns[0].Header = "Segment";
I've tried the following:
XamDataGrid.FieldLayouts[0].FieldItems[0].Label = "test";
But it doesn't work because I'm setting the columns in the code behind and not the front end like so:
DataTable dtDataGrid = new DataTable();
dtDataGrid.Columns.Add("Segment", typeof(string));
XamDataGrid.DataSource = dtDataGrid.DefaultView;
  • 29065
    You need to set the Label property off of the instance of your control, eg "grid".
    FieldItems worked for me, but you can try using the Fields too.
    eg.
    grid.FieldLayouts[0].Fields[0].Label = "test";
    If this doesn't work please send a sample isolating this.
