530
xamDataChart adding scatterplot dynamically with MVVM
I am using xamdataChart  with multiple datachart, scatterline/scattercontour etc.  I would like to dynamically add series to the chart via MVVM.
I saw a solution for this but it is quite old, from 8 years ago. I modified it a little to accept ScatterContours but I am having a problem onValueMemberPath.
I nee to have 3 datachart,two off them add scatter line, and the last one add scatter contour.
Can someone notify the problem, or simple provide my a more recent solution to the problem?
Thank you!
ps: I couln'tupload my zip so hre is my code
Main window.xaml
<Window xmlns:ig="http://schemas.infragistics.com/xaml"  x:Class="SeriesBinder.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:local="clr-namespace:SeriesBinder"
        Title="MainWindow" Height="350" Width="525">
    <Grid>
        <Grid.RowDefinitions>
            <RowDefinition Height="*" />
            <RowDefinition Height="*"></RowDefinition>
            <RowDefinition Height="50" />
        </Grid.RowDefinitions>
        <ig:XamDataChart Margin="2" >
            <local:SeriesBinderBehavior.SeriesBinder>
                <local:SeriesBinderInfo
                    SeriesSource="{Binding SeriesSource}"
                    ItemsSourcePath="Source"
                    XMemberPath="XPath"
                    YMemberPath="YPath"
                    TypePath="Type"/>
            </local:SeriesBinderBehavior.SeriesBinder>
        </ig:XamDataChart>
        <ig:XamDataChart Grid.Row="1" >
                    SeriesSource="{Binding SeriesSource2}"
                    XMemberPath="XPath"
                    YMemberPath="YPath"
                    TypePath="Type"/>
                <!--  ValuMemberPathmissing -->
        </ig:XamDataChart>
        <Button Content="Add Series" Command="{Binding AddSeries}" Grid.Row="2" Height="23" HorizontalAlignment="Left" Margin="12,15,0,0" Name="button1" VerticalAlignment="Top" Width="75" />
        <Button Content="Remove Series" Command="{Binding RemoveSeries}" Grid.Row="2" Height="23" HorizontalAlignment="Left" Margin="93,15,0,0" Name="button2" VerticalAlignment="Top" Width="94" />
        <Button Content="Clear Series" Command="{Binding ClearSeries}" Grid.Row="2" Height="23" HorizontalAlignment="Left" Margin="193,15,0,0" Name="button3" VerticalAlignment="Top" Width="75" />
        <Button Content="Reset Source" Command="{Binding ResetSeries}" Grid.Row="2" Height="23" HorizontalAlignment="Left" Margin="274,15,0,0" Name="button4" VerticalAlignment="Top" Width="75" />
    </Grid>
</Window>
Main window.cs
using Infragistics.Controls.Charts;
using System;
using System.Collections;
using System.Collections.Generic;
using System.Collections.ObjectModel;
using System.Collections.Specialized;
using System.ComponentModel;
using System.Diagnostics;
using System.Windows;
using System.Windows.Data;
using System.Windows.Input;
namespace SeriesBinder
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
            DataContext = new MainViewModel();
    #region Series Binder
    public class SeriesBinderBehavior : DependencyObject
        public static readonly DependencyProperty SeriesBinderProperty =
            DependencyProperty.RegisterAttached(
                "SeriesBinder",
                typeof(SeriesBinderInfo),
                typeof(SeriesBinderBehavior),
                new PropertyMetadata(null,
                    (o, e) =>
                        OnSeriesBiderChaged(o as XamDataChart,
                            e.OldValue as SeriesBinderInfo,
                            e.NewValue as SeriesBinderInfo);
        public static SeriesBinderInfo GetSeriesBinder(DependencyObject target)
            return target.GetValue(SeriesBinderProperty) as SeriesBinderInfo;
        public static void SetSeriesBinder(DependencyObject target, object value)
            target.SetValue(SeriesBinderProperty, value);
        private static void OnSeriesBiderChaged(
            XamDataChart chart,
            SeriesBinderInfo oldVal,
            SeriesBinderInfo newVal)
            if (chart == null)
                return;
            if (oldVal != null)
                oldVal.DetachOwner(chart);
            if (newVal != null)
                newVal.AttachOwner(chart);
    public class SeriesBinderInfo : FrameworkElement
        #region Fields
        private XamDataChart _owner;
        Dictionary<object, Series> _seriesObjectMapper;
        #endregion
        #region Constructor
        public SeriesBinderInfo()
            _seriesObjectMapper = new Dictionary<object, Series>();
        #endregion
        #region Initializing Methods
        public void AttachOwner(XamDataChart chart)
            if (_owner != null)
                DetachOwner(_owner);
            _owner = chart;
            SetBinding(DataContextProperty,
                new Binding("DataContext")
                    Source = _owner
        public void DetachOwner(XamDataChart _owner)
            _owner = null;
            _seriesObjectMapper.Clear();
            ClearValue(DataContextProperty);
        #endregion
        #region Properties
        #region SeriesSource
        private const string SeriesSourcePropertyName = "SeriesSource";
        public IEnumerable SeriesSource
            get { return (IEnumerable)GetValue(SeriesSourceProperty); }
            set { SetValue(SeriesSourceProperty, value); }
        public static readonly DependencyProperty SeriesSourceProperty =
            DependencyProperty.Register(
                SeriesSourcePropertyName,
                typeof(IEnumerable),
                new PropertyMetadata(null));
        #endregion
        #region ItemsSourcePath
        private const string ItemsSourcePathPropertyName = "ItemsSourcePath";
        public string ItemsSourcePath
            get { return (string)GetValue(ItemsSourcePathProperty); }
            set { SetValue(ItemsSourcePathProperty, value); }
        public static readonly DependencyProperty ItemsSourcePathProperty =
                ItemsSourcePathPropertyName,
                typeof(string),
        #endregion
        #region XMemberPath
        private const string XMemberPathPropertyName = "XMemberPath";
        public string XMemberPath
            get { return (string)GetValue(XMemberPathProperty); }
            set { SetValue(XMemberPathProperty, value); }
        public static readonly DependencyProperty XMemberPathProperty =
                    XMemberPathPropertyName,
                    typeof(string),
        #endregion
        #region YMemberPath
        private const string YMemberPathPropertyName = "YMemberPath";
        public string YMemberPath
            get { return (string)GetValue(YMemberPathProperty); }
            set { SetValue(YMemberPathProperty, value); }
        public static readonly DependencyProperty YMemberPathProperty =
                    YMemberPathPropertyName,
                    typeof(string),
        #endregion
        #region valueMemberPath
        private const string ValueMemberPathPropertyName = "ValueMemberPath";
        public string ValueMemberPath
            get { return (string)GetValue(ValueMemberPathProperty); }
            set { SetValue(ValueMemberPathProperty, value); }
        public static readonly DependencyProperty ValueMemberPathProperty =
                    ValueMemberPathPropertyName,
                    typeof(string),
        #endregion
        #region TypePath
        private const string TypePathPropertyName = "TypePath";
        public string TypePath
            get { return (string)GetValue(TypePathProperty); }
            set { SetValue(TypePathProperty, value); }
        public static readonly DependencyProperty TypePathProperty =
                TypePathPropertyName,
                typeof(string),
        #endregion
        #endregion
        #region Event Handlers
        void SeriesBinderInfo_CollectionChanged(object sender, NotifyCollectionChangedEventArgs e)
            switch (e.Action)
                case NotifyCollectionChangedAction.Add:
                        object seriesSource = e.NewItems[0];
                        AddSeries(seriesSource);
                    break;
                case NotifyCollectionChangedAction.Remove:
                        object seriesSource = e.OldItems[0];
                        RemoveSeries(seriesSource);
                    break;
                case NotifyCollectionChangedAction.Move:
                case NotifyCollectionChangedAction.Replace:
                case NotifyCollectionChangedAction.Reset:
                        GenerateSeries();
                    break;
                default:
                    break;
        #endregion
        #region Helper Methods
        private void RemoveSeries(object seriesSource)
            Series s = _seriesObjectMapper[seriesSource];
            SeriesType type = (SeriesType)seriesSource.GetType().GetProperty(TypePath).GetValue(seriesSource, null);
            UpdateSeriesProperties(s, type, seriesSource, true, true);
            _owner.Series.Remove(s);
            _seriesObjectMapper.Remove(seriesSource);
        private void AddSeries(object seriesSource)
            Series series = CreateSeries(type, seriesSource);
            _owner.Series.Add(series);
            _seriesObjectMapper.Add(seriesSource, series);
        private void GenerateSeries()
            _owner.Series.Clear();
            _owner.Axes.Clear();
            foreach (var item in SeriesSource)
                AddSeries(item);
        private Series CreateSeries(SeriesType type, object seriesSource)
            Series series = null;
            switch (type)
                case SeriesType.LineSeries:
                        series = new LineSeries();
                        UpdateSeriesProperties(series, type, seriesSource, true, false);
                    break;
                case SeriesType.ColumnSeries:
                        series = new ColumnSeries();
                    break;
                case SeriesType.ScatterSeries:
                        series = new ScatterSeries();
                    break;
                case SeriesType.ScatterLineSeries:
                        series = new ScatterLineSeries();
                    break;
                case SeriesType.ScatterContourSeries:
                        series = new ScatterContourSeries();
                    break;
                default:
                    break;
            return series;
        private void UpdateSeriesProperties(Series series, SeriesType type, object seriesSource, bool shouldRenewAxes, bool clearOnly)
            if (series != null)
                switch (type)
                            HorizontalAnchoredCategorySeries category = series as HorizontalAnchoredCategorySeries;
                            category.ClearValue(HorizontalAnchoredCategorySeries.ValueMemberPathProperty);
                            category.ClearValue(HorizontalAnchoredCategorySeries.ItemsSourceProperty);
                            if (!clearOnly)
                                category.SetBinding(HorizontalAnchoredCategorySeries.ValueMemberPathProperty,
                                    new Binding(YMemberPath) { Source = seriesSource });
                                category.SetBinding(HorizontalAnchoredCategorySeries.ItemsSourceProperty,
                                    new Binding(ItemsSourcePath) { Source = seriesSource });
                            if (shouldRenewAxes)
                                if (category.XAxis != null)
                                    _owner.Axes.Remove(category.XAxis);
                                if (category.YAxis != null)
                                    _owner.Axes.Remove(category.YAxis);
                                if (!clearOnly)
                                    CategoryXAxis xAxis = new CategoryXAxis();
                                    xAxis.SetBinding(CategoryXAxis.ItemsSourceProperty,
                                    xAxis.Label = "{" + seriesSource.GetType().GetProperty(XMemberPath).GetValue(seriesSource, null) + "}";
                                    NumericYAxis yAxis = new NumericYAxis();
                                    _owner.Axes.Add(xAxis);
                                    _owner.Axes.Add(yAxis);
                                    category.XAxis = xAxis;
                                    category.YAxis = yAxis;
                        break;
                            ScatterBase scatter = series as ScatterBase;
                            scatter.ClearValue(ScatterBase.XMemberPathProperty);
                            scatter.ClearValue(ScatterBase.YMemberPathProperty);
                            scatter.ClearValue(ScatterBase.ItemsSourceProperty);
                            if (!clearOnly)
                                scatter.SetBinding(ScatterBase.XMemberPathProperty,
                                    new Binding(XMemberPath) { Source = seriesSource });
                                scatter.SetBinding(ScatterBase.YMemberPathProperty,
                                scatter.SetBinding(ScatterBase.ItemsSourceProperty,
                                if (scatter.XAxis != null)
                                    _owner.Axes.Remove(scatter.XAxis);
                                if (scatter.YAxis != null)
                                    _owner.Axes.Remove(scatter.YAxis);
                                if (!clearOnly)
                                    NumericXAxis xAxis = new NumericXAxis();
                                    scatter.XAxis = xAxis;
                                    scatter.YAxis = yAxis;
                        break;
                            ScatterContourSeries scatterContour = series as ScatterContourSeries;
                            scatterContour.ClearValue(ScatterTriangulationSeries.XMemberPathProperty);
                            scatterContour.ClearValue(ScatterTriangulationSeries.YMemberPathProperty);
                            scatterContour.ClearValue(ScatterContourSeries.ValueMemberPathProperty);
                            scatterContour.ClearValue(ScatterTriangulationSeries.ItemsSourceProperty);
                            if (!clearOnly)
                                scatterContour.SetBinding(ScatterTriangulationSeries.XMemberPathProperty,
                                scatterContour.SetBinding(ScatterTriangulationSeries.YMemberPathProperty,
                                scatterContour.SetBinding(ScatterContourSeries.ValueMemberPathProperty,
                                   new Binding(ValueMemberPath) { Source = seriesSource });
                                scatterContour.SetBinding(ScatterTriangulationSeries.ItemsSourceProperty,
                                if (scatterContour.XAxis != null)
                                    _owner.Axes.Remove(scatterContour.XAxis);
                                if (scatterContour.YAxis != null)
                                    _owner.Axes.Remove(scatterContour.YAxis);
                                if (!clearOnly)
                                    scatterContour.XAxis = xAxis;
                                    scatterContour.YAxis = yAxis;
                                    // scatterContour.ValueMemberPath =
                        break;
                    default:
                        break;
        #endregion
        #region Base Overrides
        protected override void OnPropertyChanged(DependencyPropertyChangedEventArgs e)
            switch (e.Property.Name)
                case SeriesSourcePropertyName:
                        if (e.OldValue != null
                            && e.OldValue is INotifyCollectionChanged)
                            (e.OldValue as INotifyCollectionChanged).CollectionChanged -= SeriesBinderInfo_CollectionChanged;
                        if (e.NewValue != null
                            && e.NewValue is INotifyCollectionChanged)
                            (e.NewValue as INotifyCollectionChanged).CollectionChanged += SeriesBinderInfo_CollectionChanged;
                        GenerateSeries();
                    break;
                case XMemberPathPropertyName:
                case YMemberPathPropertyName:
                case ValueMemberPathPropertyName:
                case TypePathPropertyName:
                        if (SeriesSource != null)
                            GenerateSeries();
                    break;
                default:
                    break;
            base.OnPropertyChanged(e);
        #endregion
    #endregion
    #region View Model
    public class MainViewModel : PropertyChangedNotifier
        private ObservableCollection<SeriesViewModel> seriesSource;
        private ObservableCollection<SeriesViewModel> seriesSource2;
        public MainViewModel()
            SeriesSource = new ObservableCollection<SeriesViewModel>
                new SeriesViewModel
                    Source = ChartData.GenerateData(10),
                    Type = SeriesType.ColumnSeries,
                    XPath = "Date",
                    YPath = "Value",
                new SeriesViewModel
                    Source = ChartData.GenerateData(22),
                    Type = SeriesType.LineSeries,
                    XPath = "Label",
                    YPath = "Value",
                new SeriesViewModel
                    Source = ChartData.GenerateData(20),
                    Type = SeriesType.ScatterSeries,
                    XPath = "Index",
                    YPath = "Value",
                new SeriesViewModel
                    Source = ChartData.GenerateData(15),
                    Type = SeriesType.ScatterLineSeries,
                    XPath = "Index",
                    YPath = "Value",
            SeriesSource2 = new ObservableCollection<SeriesViewModel>();
        public ObservableCollection<SeriesViewModel> SeriesSource
            get { return seriesSource; }
            set { seriesSource = value; OnPropertyChagned("SeriesSource"); }
        public ObservableCollection<SeriesViewModel> SeriesSource2
            get { return seriesSource2; }
            set { seriesSource2 = value; OnPropertyChagned("SeriesSource2"); }
        public ICommand AddSeries
            get
                return new RelayCommand<object>(
                    new Action<object>(
                        (obj) =>
                            SeriesSource2.Add(
                                new SeriesViewModel
                                    Type = SeriesType.ScatterContourSeries,
                                    XPath = "Index",
                                    YPath = "Index",
                                    ValueMemberPath = "Value"
                            SeriesSource.Add(
                                new SeriesViewModel
                                    XPath = "Index",
                                    YPath = "Value",
        public ICommand RemoveSeries
            get
                    new Action<object>(
                        (obj) =>
                            if (SeriesSource.Count > 0)
                                SeriesSource.RemoveAt(0);
        public ICommand ClearSeries
            get
                    new Action<object>(
                        (obj) =>
                            SeriesSource.Clear();
        public ICommand ResetSeries
            get
                    new Action<object>(
                        (obj) =>
                                new SeriesViewModel
                                    XPath = "Date",
                                    YPath = "Value",
                                new SeriesViewModel
                                    XPath = "Label",
                                    YPath = "Value",
                                new SeriesViewModel
                                    XPath = "Index",
                                    YPath = "Value",
                                new SeriesViewModel
                                    XPath = "Index",
                                    YPath = "Value",
    public class SeriesViewModel : PropertyChangedNotifier
        private SeriesType type;
        public SeriesType Type
            get { return type; }
            set { type = value; OnPropertyChagned("Type"); }
        private IEnumerable source;
        public IEnumerable Source
            get { return source; }
            set { source = value; OnPropertyChagned("Source"); }
        private string xPath;
        public string XPath
            get { return xPath; }
            set { xPath = value; OnPropertyChagned("XPath"); }
        private string yPath;
        public string YPath
            get { return yPath; }
            set { yPath = value; OnPropertyChagned("XPath"); }
        private string valueMemberPath;
            get { return valueMemberPath; }
            set { valueMemberPath = value; OnPropertyChagned("ValueMemberPath"); }
    public class ChartData
        public DateTime Date { get; set; }
        public int Index { get; set; }
        public string Label { get; set; }
        public double Value { get; set; }
        public static ObservableCollection<ChartData> GenerateData(int count)
            ObservableCollection<ChartData> data = new ObservableCollection<ChartData>();
            Random r = new Random();
            ChartData data0 = new ChartData
                Date = DateTime.Now,
                Index = 0,
                Value = r.Next(20, 40),
                Label = "Item 0"
            data.Add(data0);
            for (int i = 1; i < count; i++)
                ChartData dat = new ChartData
                    Date = DateTime.Now.AddDays(i),
                    Index = i,
                    Label = "Item " + i,
                if (r.NextDouble() > .5)
                    dat.Value = data[i - 1].Value + r.NextDouble();
                else
                    dat.Value = data[i - 1].Value - r.NextDouble();
                data.Add(dat);
            return data;
    public class PropertyChangedNotifier : INotifyPropertyChanged
        public event PropertyChangedEventHandler PropertyChanged;
        public void OnPropertyChagned(string name)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(name));
    public enum SeriesType
        LineSeries,
        ColumnSeries,
        ScatterSeries,
        ScatterLineSeries,
    public class RelayCommand<T> : ICommand
        #region Declarations
        readonly Predicate<T> _canExecute;
        readonly Action<T> _execute;
        #endregion
        #region Constructors
        /// <summary>
        /// Initializes a new instance of the <see cref="RelayCommand&lt;T&gt;"/> class and the command can always be executed.
        /// </summary>
        /// <param name="execute">The execution logic.</param>
        public RelayCommand(Action<T> execute)
            : this(execute, null)
        /// <summary>
        /// Initializes a new instance of the <see cref="RelayCommand&lt;T&gt;"/> class.
        /// </summary>
        /// <param name="canExecute">The execution status logic.</param>
        public RelayCommand(Action<T> execute, Predicate<T> canExecute)
            if (execute == null)
                throw new ArgumentNullException("execute");
            _execute = execute;
            _canExecute = canExecute;
        #endregion
        #region ICommand Members
        public event EventHandler CanExecuteChanged
            add
                if (_canExecute != null)
                    CommandManager.RequerySuggested += value;
            remove
                    CommandManager.RequerySuggested -= value;
        [DebuggerStepThrough]
        public virtual Boolean CanExecute(Object parameter)
            return _canExecute == null ? true : _canExecute((T)parameter);
        public virtual void Execute(Object parameter)
            _execute((T)parameter);
        #endregion
    #endregion
