we are CategoryDateTimeXAxis in our chart and want to see is there any option to extend the last data point value to end of the chart? Please refer the attached screen shot.
We need to show the chart as in below
We are using timer to set the Min and Max value of XAxis
Hello Member,
I have been investigating into this behavior you are looking to achieve, and currently the only way to achieve this is if the value of the last point in your series is equal to that last point on the CategoryDateTimeXAxis. You had mentioned that you are using a timer to set the Min and Max values of the XAxis – you will need to synchronize this with your data points in order to extend the last point to the end such that the Max value is the X-Axis value of the last point in your data.
