We've upgrade recently the project from Infragistics v16.2 to v18.2 and during testing we discovered that one functionality is not working. After long analysis I figure out that this functionality was working with older version but it got broken after update.
Unfortunately I cannot provide more specific details since creating a reproduction problem might not be simple due it involves a lot of actions.
Here is a stack trace:
InfragisticsWPF.Controls.Menus.XamDataTree.dll!Infragistics.Controls.Menus.NodesManager.DataManager_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown InfragisticsWPF.DataManager.dll!Infragistics.DataManagerBase.OnCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown InfragisticsWPF.DataManager.dll!Infragistics.DataManagerBase.OnDataSourceCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown InfragisticsWPF.DataManager.dll!Infragistics.DataManager<Eaf.Client.Mango.Navigation.Base.TreeItemViewModel>.OnDataSourceCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown InfragisticsWPF.DataManager.dll!Infragistics.DataManagerBase.SetDataSource.AnonymousMethod__206_0(Infragistics.DataManagerBase instance, object s, System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown InfragisticsWPF.dll!Infragistics.WeakEventHandler<Infragistics.DataManagerBase, System.Collections.Specialized.INotifyCollectionChanged, System.Collections.Specialized.NotifyCollectionChangedEventArgs>.OnEvent(object source, System.Collections.Specialized.NotifyCollectionChangedEventArgs eventArgs) Unknown System.dll!System.Collections.ObjectModel.ObservableCollection<Eaf.Client.Mango.Navigation.Base.TreeItemViewModel>.OnCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs e) Unknown System.dll!System.Collections.ObjectModel.ObservableCollection<System.__Canon>.ClearItems() Unknown mscorlib.dll!System.Collections.ObjectModel.Collection<XXXXXX.Navigation.Base.TreeItemViewModel>.Clear() Unknown() Unknown
Hello Tomas,
Thank you for your post. This issue is known, has been fixed internally, and will receive a fix in the next service release estimated to release on April 5.
It was logged as development issue 260701 internally, and I have created you a private support case so that you can be notified when a fix becomes available. This support case has an ID of CAS-201237-J9S1K0 and you can access it after signing into your account, here.
Forgot to mention that this happens on treeNode Clear:
cellNode.Nodes.Clear();
