975
CellValuePresenter style with setter for Template causes exception
i get an runtime error when putting the style below to fieldsettings.CellValuePresenterStyle.
The problem did not occur with v12.1
The problem occurs since we use 13.1.
Is this a known bug and is it solved in 14.1? (The latest version we owe)
            <Style TargetType="igDP:CellValuePresenter">
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="igDP:CellValuePresenter">
                            <CheckBox HorizontalAlignment="Center" IsChecked="{Binding DataItem.Model.IstBearbeitbarProperty.Value}"/>
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
            </Style>
Exception:
System.ArgumentException: FieldSettings.CellValuePresenterStyle's TargetType setting can only be null or a type that derives from CellValuePresenter or is a base class of CellValuePresenter, CellValuePresenter is invalid.
Parametername: FieldSettings.CellValuePresenterStyle
bei Infragistics.Windows.Utilities.ValidateTargetTypeOfStyle(Style style, Type targetType, String propertyName)
bei Infragistics.Windows.DataPresenter.FieldSettings.ValidateCellValuePresenterStyle(Object value)
bei System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
bei System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
bei Infragistics.Windows.DataPresenter.FieldSettings.set_CellValuePresenterStyle(Style value)
bei Rehm.Utils.Gui.OrmUtilGui.CListGui.NewField(CColumn aColumn, List`1 aFieldSortDescriptions, Boolean aShowEmbeddedCellGuis1) in i:\Prj\Git01\M\GWS2\UtilsGui\Gui\Orm\CListGui.xaml.cs:Zeile 950.
bei Rehm.Utils.Gui.OrmUtilGui.CListGui.NewField(CColumn aColumn, List`1 aFieldSortDescriptions) in i:\Prj\Git01\M\GWS2\UtilsGui\Gui\Orm\CListGui.xaml.cs:Zeile 761.
bei Rehm.Utils.Gui.OrmUtilGui.CListGui.<>c__DisplayClass13.<RefreshListViewNow2>b__e(CColumn aPair) in i:\Prj\Git01\M\GWS2\UtilsGui\Gui\Orm\CListGui.xaml.cs:Zeile 1098.
bei Rehm.Utils.Extensions.Util.Transform[TIn,TOut](IEnumerable`1 aIns, Func`2 aCreateOut) in i:\Prj\Git01\M\GWS2\Utils\Extensions.cs:Zeile 1156.
bei Rehm.Utils.Gui.OrmUtilGui.CListGui.RefreshListViewNow2() in i:\Prj\Git01\M\GWS2\UtilsGui\Gui\Orm\CListGui.xaml.cs:Zeile 1095.
bei Rehm.Utils.Gui.OrmUtilGui.CListGui.RefreshListViewNow() in i:\Prj\Git01\M\GWS2\UtilsGui\Gui\Orm\CListGui.xaml.cs:Zeile 1002.
bei Rehm.Utils.Gui.OrmUtilGui.CListGui.<get_RefreshEntpreller>b__4() in i:\Prj\Git01\M\GWS2\UtilsGui\Gui\Orm\CListGui.xaml.cs:Zeile 681.
