Hi
I want to enable the scrolling bar in your example in the infragistic package samples.
Hello Michel,
I am attaching an isolated version of the DataSelector sample in the Infragistics for WPF Samples Browser with a scrollable XamDataTree – essentially implementing the behaviors mentioned in my first response. I hope this helps you.
XamPivotGridCustomizedDataSelectorDemo.zip
I want to use the DataSelector.xaml layout in the wpf example...
can you fix the problem ?
thx
I have been investigating into this behavior, and I can confirm that the XamPivotDataSelector will normally scroll when using it – this particular sample project in the Infragistics WPF Samples Browser is currently showing how you can modify the template of the controls within the data selector and essentially make it look different.
In the sample, the XamDataTree is re-templated, and for some reason when this sample was built, the ScrollBars were taken out of the default template for the XamDataTree. I am unsure why this was done, but for this particular sample, it appears to have been intentional. If you want to change this, you can do the following:
I am unsure if you are running the Samples Browser from its source code or if you are running an isolated version of this sample, but you will need to replace the re-templated XamDataTree with the default-template one. This default template can be found in the generic.xaml file commonly found at the following directory when Infragistics controls are installed:
C:\Program Files (x86)\Infragistics\<version>\WPF\DefaultStyles\DataTree\generic.xaml
If you take the default template for XamDataTree and replace it in the sample, you should be able to scroll the tree in the data selector.
