90
Binding to a list of string
My case is like this:
I have a List
public List<string> CategoryList{ get; set; }
In xmal, I bind like this
DataSource="{Binding CategoryList, Mode=OneWay}"
1. I don't know how to write the TextField label.
2. After I set this list to a list of string, the grid shows the row numbers but no data.
How can I display this list of string in the xamDataGrid?
  • 1560
    I have been looking into your question, however, by default the approach with defining Fields, TextFields, etc. and set their name property works if the field corresponds to a specific property of the underlying data.
    In your scenario instead of defining field layout, I can suggest two approaches:
    1. Set the AutoGenerateFields property to true and in the grid's  FieldLayoutInitialized event handler gets the field and set its Label per your requirement:
     private void XamDataGrid_FieldLayoutInitialized(object sender, Infragistics.Windows.DataPresenter.Events.FieldLayoutInitializedEventArgs e)
                e.FieldLayout.Fields["Value"].Label = "My Label";
    2. Instead of TextField define it as UndoundField:
    <igDP:XamDataGrid DataSource="{Binding Mode=OneWay}">
                <igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:FieldLayoutSettings AutoGenerateFields="False"/>
                </igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:XamDataGrid.FieldLayouts>
                    <igDP:FieldLayout>
                        <igDP:UnboundField BindingPath="." Name="Value" Label="My Label"/>
                    </igDP:FieldLayout>
                </igDP:XamDataGrid.FieldLayouts>
            </igDP:XamDataGrid>
    I have attached a sample application, that uses the second approach, however, as a comment, you could find the first as well. Please test it on your side and let me know if I may be of any further assistance.
    Sincerely,
    Teodosia Hristodorova
    Associate Software Developer
    7356.XDG_to_List.zip
