is there a default menu for the rich text editor? One that just displays pretty much everything with the usual icons?I can't find anything.
Hello Martin,
Thank you for the update. so i believe you are looking for your image as a context menu of XamRichTextEditor, if so then you might not able to have exact same UI . I would recommend you to refer to this online help document explaining how to manage context menu in XamRichEditor.
Let me know if you have any question.
Sincerly,
Divya Jain
Basically this, from your samples browser.I'd think there would be an option to display a build in menu.
Thank you for your post . In order to understand your requirement can you share any screen shot of what you are looking for?
