I have a numeric editor that works with 2 deicmal places as default ,i want it to take 3 decimal places.I have a currency column based on which from code behind i want the editor to take 2 or 3 decimal places with a double number .
We had this is webforms infragistics but i cannot find similar in WPF
txtRegistrationCharges.MinDecimalPlaces = "3"
Yes, my bad, you are correct. The initial set of curly braces is used as escape sequence when setting up the mask in XAML. When doing it in code behind it shouldn't be there.
Sincerely,
Tihomir TonevAssociate Software DeveloperInfragistics
Thanks for your help
txtActamt.Mask = "{double:-15.3}";
This seems to be working ,without {} in the beginning
You can configure the editor's mask property, which will modify the way the result is output:
this.numericEditorName.Mask = "{}{double:-50.3}";
This mask will have the editor display up to 50 digits in the integer part, and 3 digits in the fraction part. You can read more about masks here:
https://ko.infragistics.com/help/wpf/xameditors-masks
As well as general field configuration in case you want to have them as a field:
https://ko.infragistics.com/help/wpf/xamdatagrid-fields-editors-configuration-
Should you have any further questions, please let me know.
