640
TabGroupPane + PaneCloseAction.RemovePane issue
After a lot of debugging  I think I've found an issue when setting  a ContentPane.CloseAction =PaneCloseAction.RemovePane and having a TabGroupPane without the Name property set.
Let me illustrate it with a sample
 XAML
I have 2 TabGroupPanes. Only difference is that 1 have its Name property set and the other one doesn't.
         <igDock:XamDockManager x:Name="dockManager" Grid.Row="0" Grid.Column="0">
            <igDock:DocumentContentHost>
                <igDock:SplitPane Name="SplitPane1">
                    <igDock:TabGroupPane Name="TabGroupPane1" />
                </igDock:SplitPane>
                <igDock:SplitPane Name="SplitPane2">
                    <igDock:TabGroupPane />
                </igDock:SplitPane>
            </igDock:DocumentContentHost>
        </igDock:XamDockManager>
I also have 3 buttons to add ContentPane to each tab and to Ouput the TabGroupPane properties:
<Button Name="btnOutputProperties" Content="Output TabGroupPanes Properties" Grid.Row="1" Click="btnOutputProperties_Click" ></Button>
        <Button Name="btnAddContentTabGroup1" Content="Add Content TabGroupPane #1" Grid.Row="2" Click="btnAddContentTabGroup1_Click"></Button>
        <Button Name="btnAddContentTabGroup2" Content="Add Content TabGroupPane #2" Grid.Row="3" Click="btnAddContentTabGroup2_Click"></Button>
Code Behind
        TabGroupPane tabGroupPane2;
        int iTab1 = 0;
        int iTab2 = 0;
        public Window1()
            InitializeComponent();
            tabGroupPane2 = (TabGroupPane)SplitPane2.Panes[0];
        private void btnAddContentTabGroup1_Click(object sender, RoutedEventArgs e)
            RichTextBox rtb = new RichTextBox();
            ContentPane newContentPane = new ContentPane();
            newContentPane.Content = rtb;
            newContentPane.CloseAction = PaneCloseAction.RemovePane;
            iTab1 += 1;
            newContentPane.Header = "1." + iTab1;
            TabGroupPane1.Items.Add(newContentPane);
        private void btnAddContentTabGroup2_Click(object sender, RoutedEventArgs e)
            iTab2 += 1;
            newContentPane.Header = "2." + iTab2;
            tabGroupPane2.Items.Add(newContentPane);
        private void btnOutputProperties_Click(object sender, RoutedEventArgs e)
            Console.WriteLine("Parent TabGroupPane #1 " + TabGroupPane1.Parent);
            Console.WriteLine("Parent TabGroupPane #2 " + tabGroupPane2.Parent);
To see the issue Run the application and:
  1. Click  "Add Content TabGroupPane #1" => ContentPane "1.1" is added
  2. Click  "Add Content TabGroupPane #2" => ContentPane "2.1" is added
  3. Click  "Output TabGroupPanes Properties", you get the following output:
    Parent TabGroupPane #1 Infragistics.Windows.DockManager.SplitPane
    Parent TabGroupPane #2 Infragistics.Windows.DockManager.SplitPane
  4. Close the ContentPanes "1.1" and "2.1"
  5. Click "Output TabGroupPanes Properties", you get the following output:
  6. Click  "Add Content TabGroupPane #1" => ContentPane "1.2" is added
  7. Click  "Add Content TabGroupPane #2" => No ContentPane is added
Notice:
  • In step 5. the Parent property is set to null (same happened to me with other attached property of other application)
  • In method private void btnAddContentTabGroup2_Click(object sender, RoutedEventArgs e) if you comment the line //newContentPane.CloseAction = PaneCloseAction.RemovePane; =>
    - In step 5. you get Parent TabGroupPane #2 Infragistics.Windows.DockManager.SplitPane
    - In step 7. you get ContentPane "2.2" is added
  • If you add a Name to the 2nd TabGroupPane (ex: "MyTabGroupPane2") =>
Workaround for now is to have the Name property set, but I would like to hear other thoughts.
Claudio.
  • 54937
    This is actually intended behavior. When a SplitPane/TabGrouppane is no longer needed (e.g. you remove/move all the contentpanes elsewhere) the dockmanager will remove the splitpane/tabgroup. This is done to remove the overhead of having unneeded/unused panes remaining in the visual/logical tree. A pane will not be removed if its Name property has been set on the assumption that you will be using that pane again (plus since VS would have created a member variable for it).
