130
Binding numeric value into subtitle
is there a simple way to bind a numeric value to the subtitle ?
Following scenario:
I have multiple series and each one of them with with different underlying data depending on the selected item in the combo editor.
So for each series there has to be a different value that I want to display in the subtitle of the same XamDataChart:
I.e. if I select the first chart, the subtitle should show "s_max = 10". Selection of the second chart should show "s_max = 5" and so on.
Thank you in advance.
Best regards,
Julian
