Hi there,
my wpf app is a xamribbonwindow.
I have set the Datacontext in XAML like this:
<igRibbon:XamRibbonWindow.DataContext> <vm:ViewModel/> </igRibbon:XamRibbonWindow.DataContext>
I do have problem with databinding on the ribbon
<igRibbon:XamRibbon x:Name="myRibbon" DockPanel.Dock="Top" SelectedTab="{Binding SelectedRibbonTab}" RibbonTabItemSelected="myRibbon_RibbonTabItemSelected" >
The event "myRibbon_RibbonTabItemSelected" is being fired, works like expected.
The Binding to SelectedRibbonTab in the ViewModel does not work. This property never gets updated.
On the other hand:
<igRibbon:ButtonTool Caption="button" Command="{Binding RibbonCommand}" CommandParameter="but1" />
The ribbon command binding (same viewmodel) works like expected.
Is this a bug, or whats goi8ng wrong here?
Thanks for any idea.
Thomas
Hi Nicholas,
thanks for the quick feedback.
Hello Thomas,
I had a look at your issue with the xamribbon databinding not working. After investigating I have found this issue to be a bug. I have logged this with a development id of 271447. You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
I have created a private support case for you with an id of CAS-209461-P6C1C2 you can find it here: https://ko.infragistics.com/my-account/support-activity
Regards.
Nicholas
