I have a line series in XamDataChart. It gets a white ara as seen in the attached picture. How do I remove it? I only want the line.
Hilma Maria
Hi Divya,
It turned out we had a style for "Path" that would set its fill to white, and this caused the problem. Now I have set it to transparent in my XamDataChart and it works as it should.
Thanks for your help.
Hilma
Hello Hilma,
I followed the steps you suggested ,created a sample of XamDataChart line series and applied RoyalDark theme.
When I run the sample I don’t find white white are like you have in your screenshot.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
DataChart_code_beind.zip
