845
XamCode128Barcode not showing text when created in code
I have the following XAML inside a user control of mine to display a barcode. This works fine when the barcode has to be displayed on the application's UI.
<ig:XamCode128Barcode CodeType="Standard"
                      Data="{Binding Sku}"
                      ShowText="True"
                      ErrorMessageText=""
                      BarsFillMode="EnsureEqualSize"
                      UseLayoutRounding="True"
                      Stretch="Uniform"
                      Background="Transparent"/>
This is what get's displayed on the UI:
Ideally I'd use this for printing the barcode as well, but for reasons I don't understand the surrounding code doesn't work.
To avoid this problem I've modified the code so that it creates the barcode in code:
var element = new XamCode128Barcode
Data = item.Sku     CodeType = Code128CodeType.Standard,     ShowText = true,     BarsFillMode = BarsFillMode.EnsureEqualSize,     UseLayoutRounding = true,     Stretch = Stretch.Uniform,     MinHeight = 40,     MinWidth = 180,     Foreground = Brushes.Black,     Background = Brushes.White };
This works in so far as it displays the barcode. However, it doesn't display the text as shown in this screenshot of a PDF created by the printing code.
The code is correct and scans.
I've tried this with other barcode types and they exhibit the same behaviour.
What am I missing here? Why doesn't the text display? It's not a data binding issue as the "ShowText" property is set explicitly.
