370
Update color on column
I have a xamdatachart with  a columnseries. I set the color on my columns using the AssignCategoryStyle event in a behavior like this:
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/122420/xamdatachart-columnseries-set-color-on-individual-column/539090
Now I want the color of the column to be updated when the color on my item is updated. The brush on my item notifies when it is changed and I have created a subscription for this that gets called:
 private void AssociatedObject_AssigningCategoryStyle(object sender, AssigningCategoryStyleEventArgs args)
if (args.GetItems(args.StartIndex, args.EndIndex)[0] is MyDataItem currentColumn)
this.brushSubscription = currentColumn.AsObservable(x => x.Brush)
.Subscribe(_ =>
args.Fill = currentColumn.Brush;
but the color on the column is not updated unless I resize my application window. How can I get the new color to show on my column?
Hilma
  • 34810
    Hello Hilma,
    I have been investigating into the behavior you are looking to achieve in this case, and in order to notify the series that you are changing the styling of that something has changed, you will need to call the NotifyVisualPropertiesChanged() method on that series. This will cause the AssigningCategoryStyle event to fire again for that series.
