1470
XamTileManager explicit rows and columns
Hi there
How do i achieve following:
I have a tile manager, with 4 tiles. 2 Columns, 3 Rows. Tile on second column has a rowspan of 2. Now when i drag the tile on row 3, which has a column span of 2, it's stops always where the next row would start, instead of been able to drag it so far to the top, as i would like?
Hard to describe, so i attached a sample. There are the four tiles:
'Info01' (red)
'Info02' (yellow)
'Object' (blue)
'Evt' (green)
And when i want to make the tile 'Evt' bigger, as i drag it's top border more to the top, it's stops at the height of tile 'Info02' (where the second row starts). When i let it go, and drag again, i'm able to make it a little bigger, till i reach the top of the mentioned row. And i can do this, till i kinda reach the top.
Sample:
XamTileManager_Test03.zip
Regards
  • 7535
    Hello Andreas,
    Thank you for your post. I am able to reproduce the behavior you described.
    I discussed the matter with the team we are not sure if this behavior is by design or bug in the control itself.
    In response to this issue being logged, I have opened a new private support case for you that I will be linking to this issue so you can be notified when a fix or other resolution becomes available. This private case has an ID of CAS-212202-R4L1B2 and you can access it here: <https://ko.infragistics.com/my-account/support-activity>
