925
xamSpreadsheet crashing problem
We have encountered NullReferenceException thrown during execution of the  ExitEditModeAndUpdateActiveCell spreadsheet command. The following steps reproduce the issue:
  • Select any dropdown cell.
  • Enter any invalid value into the cell via Edit mode.
  • Without exiting from Edit mode, click on the Formula Bar.
  • Press "Cancel" on the Dialog prompt.
How can we avoid NullReferenceException in this scenario? A sample application which reproduces the issue is attached. SpreadsheetCrash.zip
best ergards,
Tomas
  • 34810
    Hello Tomas,
    I have been investigating into the behavior you are seeing, and I am able to reproduce this exception with the sample project you provided both with an invalid value as well as a valid one when clicking into the formula bar and executing the ExitEditModeAndUpdateActiveCell command.
    This behavior is unexpected, and as such I have asked our engineering staff to examine it further. I have logged this behavior in our internal tracking system with a development ID of 273025. I have also created a private support case for you that I will be linking this development issue to. It has an ID of CAS-212678-Y0P3Z8 and you can access it here: https://ko.infragistics.com/my-account/support-activity.
