is there any one how can tell my what are the equal in c#
DisplayLayout.Bands(0).Summaries
Dim diffMm As SummarySettings = grdOmsætning.DisplayLayout.Bands(0).Summaries("DiffMm") diffMm.CustomSummaryCalculator = New clsCalculateDiffMm diffMm.SummaryType = SummaryType.Custom Dim diffKr As SummarySettings = grdOmsætning.DisplayLayout.Bands(0).Summaries("DiffKr") diffKr.CustomSummaryCalculator = New clsCalculateDiffKr diffKr.SummaryType = SummaryType.Custom Dim diffMmProcent As SummarySettings = grdOmsætning.DisplayLayout.Bands(0).Summaries("DiffMmProcent") diffMmProcent.CustomSummaryCalculator = New clsCalculateDiffMmProcent diffMmProcent.SummaryType = SummaryType.Custom Dim diffKrProcent As SummarySettings = grdOmsætning.DisplayLayout.Bands(0).Summaries("DiffKrProcent") diffKrProcent.CustomSummaryCalculator = New clsCalculateDiffKrProcent diffKrProcent.SummaryType = SummaryType.Custom
Hello Thomas,
If you are converting from VB in Windows Forms to C# in WPF, that also likely means that you are converting to using a XamDataGrid (WPF) from the UltraGrid (Windows Forms). If this is case, then it’s worth noting that the APIs of the XamDataGrid are a bit different than the UltraGrid, and you may find that not everything can be "directly" brought over.
Still, we do have a documentation article about adding summaries to the grid, and I would recommend you review it here: https://ko.infragistics.com/help/wpf/xamdatapresenter-programmatically-add-summaries-to-a-field.
