925
Spreadsheet sorting issue
We have encountered another spreadsheet issue when trying to sort the spreadsheet rows. The issue occurs when we try to sort the rows from the context menu (right mouse click -> Sort -> Sort A to Z / Sort Z to A). The header row gets misplaced in a way as it would be an usual data row.
Sorting problem
It looks like an empty column between non-empty ones breaks somehow the correct behavior, but we need it working with empty columns as well.
How can we solve this issue?
Steps to reproduce in the attached sample application:
  • Right mouse button click on any non-empty column;
  • Select Sort -> Sort A to Z / Sort Z to A in the context menu.
SpreadsheetSortIssue.zip
Parents
No Data
Reply
  • 7535
    Hello Tomas,
    Thank you for contacting. I am able to reproduce the issue you described.
    The sorting behavior is not working correctly when empty column is available in the spreadsheet.
    I have logged this behavior into our internal bug tracking system with id 273442.
    I have opened a new private support case for you that I will be linking to this issue so you can be notified when a fix or other resolution becomes available. This private case has an ID of C-00220087 and you can access it here: https://account.infragistics.com/support-cases
    Let me know if you have any question.
    Divya Jain
Children
No Data
