925
Collection modified exception on click Auto-Hide pinned panel
On click Auto-hide command in the header of panel crashes with exception "Collection was modified; enumeration operation may not execute". Stack trace is fallowing:
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
   at System.Collections.Generic.HashSet`1.Enumerator.MoveNext()
   at Infragistics.Controls.Menus.NodeLayout.NotifyNodeManagers_PropertyChanged(PropertyChangedEventArgs e)
   at Infragistics.Controls.Menus.NodeLayout.OnPropertyChanged(String propertyName)
   at Infragistics.Controls.Menus.NodeLayout.Tree_PropertyChanged(Object sender, PropertyChangedEventArgs e)
   at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e)
   at Infragistics.Controls.Menus.XamDataTree.OnPropertyChanged(String name)
   at Infragistics.Controls.Menus.XamDataTree.IsDraggableChanged(DependencyObject obj, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
   at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents)
   at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle)
   at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache)
   at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.UpdateStyleProperty()
   at System.Windows.FrameworkElement.InvalidateTreeDependentProperties(TreeChangeInfo parentTreeState, Boolean isSelfInheritanceParent, Boolean wasSelfInheritanceParent)
   at System.Windows.FrameworkElement.OnAncestorChangedInternal(TreeChangeInfo parentTreeState)
   at System.Windows.TreeWalkHelper.OnAncestorChanged(DependencyObject d, TreeChangeInfo info, Boolean visitedViaVisualTree)
   at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree)
   at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree)
   at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree)
   at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree)
   at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren)
   at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren)
   at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d)
   at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode)
   at MS.Internal.PrePostDescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode)
   at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation)
   at System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
   at System.Windows.FrameworkElement.RemoveLogicalChild(Object child)
   at Infragistics.Windows.DockManager.SplitPane.Infragistics.Windows.DockManager.ISplitElementCollectionOwner.OnElementRemoved(FrameworkElement oldElement)
   at Infragistics.Windows.DockManager.ObservableSplitElementCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
   at Infragistics.Collections.ObservableCollectionExtended`1.RemoveItem(Int32 index)
   at System.Collections.ObjectModel.Collection`1.RemoveAt(Int32 index)
   at Infragistics.Windows.DockManager.SplitPane.Infragistics.Windows.DockManager.IContentPaneContainer.RemoveContentPane(ContentPane pane, Boolean replaceWithPlaceholder)
   at Infragistics.Windows.DockManager.XamDockManager.ProcessPinnedState(ContentPane pane, PaneLocation location, Boolean allowShowFlyout)
   at Infragistics.Windows.DockManager.ContentPane.VerifyIsPinnedStateSynchronous(Object allowShowFlyout)
The view contains quite few panels and all other working just fine except only one. How to fix this problem?
Here is part of our view containing 4 panels inside of multiple tabs:
The xaml is created using XamDocManager with SplitPane containing ContentPanes:
	<Grid>
		<igDock:XamDockManager LayoutMode="FillContainer" >
			<igDock:XamDockManager.Panes>
				<igDock:SplitPane Width="250" SplitterOrientation="Horizontal">
					<igDock:ContentPane Header="Toolbox" Style="{StaticResource PinnedPanel}"
								igDock:SplitPane.RelativeSize="100,300"
								help:ContextSensitiveHelpProvider.HelpContent="{Binding Source={x:Static ov:HelpContentOverview.CONFIG_CELL_TOOBOX}}">
						<igDock:ContentPane.Resources>
							<ResourceDictionary Source="../Resources/ComponentsViewResources.xaml"></ResourceDictionary>
						</igDock:ContentPane.Resources>
						<core:XamDataTreeEx x:Name="EquipmentCapaTree"
								ItemsSource="{Binding Path=EquipmentComponentCapabilities}" IsExpandedMemberPath="IsExpanded"
								BorderThickness="0"
								AllowDragDropCopy="True"
								SelectedItem="{Binding SelectedEquipmentComponent}"
								Focusable="True">
							<i:Interaction.Behaviors>
								<coreBehaviors:XamDataTreeDragDropBehavior
									DragDropCommand="{Binding Path=Commands[DoDragDrop]}"
									DragItem="{Binding DragItem}"
									DropItem="{Binding DropItem}"/>
							</i:Interaction.Behaviors>
							<ig:XamDataTree.GlobalNodeLayouts>
								<ig:NodeLayout Key="EquipmentCapabilityViewModel"
												TargetTypeName="EquipmentCapabilityViewModel" DisplayMemberPath="Name">
								</ig:NodeLayout>
								<ig:NodeLayout Key="EquipmentComponentViewModel"
											IsDraggable="True"
											TargetTypeName="EquipmentComponentViewModel"
											DisplayMemberPath="EquipmentComponents.Name">
									<ig:NodeLayout.ItemTemplate>
										<DataTemplate>
											<Grid>
												<StackPanel Orientation="Horizontal" AllowDrop="True" Name="CapaInfo">
													<TextBlock Text="{Binding Data.FriendlyName}"/>
													<ig:DragDropManager.DragSource>
														<ig:DragSource IsDraggable="True" DragChannels="ChannelA"
																	DragEnd="OnEquipmentCapaTreeDragEnd" DragStart="OnDragStart">
														</ig:DragSource>
													</ig:DragDropManager.DragSource>
													<ig:DragDropManager.DropTarget>
														<ig:DropTarget IsDropTarget="False" HighlightOnDragStart="True"/>
													</ig:DragDropManager.DropTarget>
													<StackPanel.ToolTip>
														<ToolTip Content="{Binding Path=Data.Description}"
																	Style="{StaticResource bubbleToolTip}"/>
													</StackPanel.ToolTip>
												</StackPanel>
											</Grid>
										</DataTemplate>
									</ig:NodeLayout.ItemTemplate>
								</ig:NodeLayout>
							</ig:XamDataTree.GlobalNodeLayouts>
							<ig:XamDataTree.SelectionSettings>
								<ig:TreeSelectionSettings NodeSelection="Single" />
							</ig:XamDataTree.SelectionSettings>
						</core:XamDataTreeEx>
					</igDock:ContentPane>
