Hi support team,
On the XamDataGrid in the attached sample application I don't know how to filter in additional rows that don't match the comparison filter.
The grid shows a flat list of a tree item hierarchy in behind. The expected behavior on filtering the DisplayText column is that all rows matching the criteria plus parents and children are filtered in. How can I archive this?
Sample project (corrected): 6710.XamDataGrid_HowToFilterInAdditionalRows.zip
I am glad to hear the issue has been resolved.
Thanks for support. The problem was resolved and your shown screenshot shows intended behavior.
For some reason VS could not locate resources, but I have the project running now.
When I filter DisplayText, the grid is filtering all parent and child records correctly on my end:
Is this not the behavior you are looking for?
Please let me know how this should look like if it is not the intended view.
Sincerely,
Tihomir TonevSoftware DeveloperInfragistics
Hi Tihomir,
Sample solution contains Infragistics assembly references and all other ones coming with .NET framework. So which ones you after?
The attached project have a lot of custom references to files not present in the attachment.
Can you please guide me with steps how to recreate the project.
Looking forward to your reply.
