I've followed the instructions here - https://ko.infragistics.com/help/wpf/xampivotgrid-editingdatacells - to add a validator for edits to my xamPivotGrid. The screenshot shows a tootlip appearing on the invalid data.
However, I don't get a tootlip. The validation fires and the cell is outlined in red. If I add a validation summary control to the page the validation error is correctly shown in that so the validator is being called and is firing correctly.
I tried copying the style template for the xamPivotGrid but I couldn't see any tootlip definitions in it all.
How do I get the tooltip to appear?
Hello Kevin,
I have put together a sample project that uses a converter to get the ErrorContent for the ToolTip rather than directly indexing the Validation.Errors collection. This prevents the System.Windows.Data Error. I am attaching the sample project here.
XamPivotGridValidationTooltipDemo.zip
Thanks for the answer.
I've implemented it, but unfortunately the tooltop is still not appearing. I'm getting this error in Visual Studio's output window:
> System.Windows.Data Error: 17 : Cannot get 'Item[]' value (type 'ValidationError') from '(Validation.Errors)' (type 'ReadOnlyObservableCollection`1'). BindingExpression:Path=(0)[0].ErrorContent; DataItem='PivotEditControl' (Name=''); target element is 'PivotEditControl' (Name=''); target property is 'ToolTip' (type 'Object') ArgumentOutOfRangeException:'System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
> Parameter name: index'
I think this means that the errors collection is empty but if I set a break point in the CellEditing event handler that does the validation I can see that the errors collection has one entry,
I have been investigating into the behavior you are reporting, and it appears that the screenshot shown in the documentation may be a duplicate to the Silverlight XamPivotGrid back when we supported Silverlight. The Silverlight XamPivotGrid had some differences to the WPF one, and as far as I can see, the WPF one never had a red tooltip like this.
Still, I have put together some tests on my end, and I have figured out a way to get a tooltip into the cell when an error is present using the code in the documentation article. The code for this is below:
<Style x:Key="editorStyle" TargetType="{x:Type ig:PivotEditControl}"> <Style.Triggers> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=(Validation.HasError)}" Value="True"> <Setter Property="ToolTip" Value="{Binding RelativeSource={RelativeSource Self}, Path=(Validation.Errors)[0].ErrorContent}"/> </DataTrigger> </Style.Triggers> </Style>
If you take this Style and apply it to the EditorStyle property on the XamPivotGrid, this should allow you to show the content of your validation error in a ToolTip.
