Hi thereWhen we use a ComboBoxField in a XamDataGrid, it throws an exception, when a user closes a window and I'm stuck with finding the issue.Can you please have a look and let me know how to fix it? Or where to start at least?StackTrace:
2022-11-09 15:01:39.6152|ERROR|general|Source: System.Private.CoreLib Message: Exception has been thrown by the target of an invocation. StackTrace: at System.RuntimeMethodHandle.InvokeMethod(Object target, Span`1& arguments, Signature sig, Boolean constructor, Boolean wrapExceptions) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Delegate.DynamicInvoke(Object[] args) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)Source: PresentationFramework Message: Beim Auswerten der Style-Eigenschaft für Element "Infragistics.Windows.Editors.XamComboEditor" wurde ein zyklischer Verweis gefunden. StackTrace: at System.Windows.FrameworkElement.UpdateStyleProperty() at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation) at System.Windows.FrameworkElement.OnVisualParentChanged(DependencyObject oldParent) at System.Windows.Media.Visual.FireOnVisualParentChanged(DependencyObject oldParent) at System.Windows.Media.Visual.RemoveVisualChild(Visual child) at System.Windows.FrameworkElement.set_TemplateChild(UIElement value) at System.Windows.StyleHelper.DetachGeneratedSubTree(FrameworkElement feContainer, FrameworkContentElement fceContainer) at System.Windows.StyleHelper.ClearGeneratedSubTree(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.Controls.ContentPresenter.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Controls.ContentPresenter.OnContentTemplateChanged(DataTemplate oldContentTemplate, DataTemplate newContentTemplate) at System.Windows.Controls.ContentPresenter.OnContentTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.StyleHelper.InvalidateDependents(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, FrugalStructList`1& dependents, Boolean invalidateOnlyContainer) at System.Windows.StyleHelper.OnTriggerSourcePropertyInvalidated(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, DependencyPropertyChangedEventArgs changedArgs, Boolean invalidateOnlyContainer, FrugalStructList`1& triggerSourceRecordFromChildIndex, FrugalMap& propertyTriggersWithActions, Int32 sourceChildIndex) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.DataItemPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.CellValuePresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyPropertyKey key, Object value) at Infragistics.Windows.DataPresenter.CellValuePresenter.SyncPendingIsDataErrorTemplateActive() at Infragistics.Windows.DataPresenter.CellValuePresenter.UpdateDataError() at Infragistics.Windows.Editors.XamComboEditor.OnLimitToListChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Editors.ValueEditor.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Editors.TextEditorBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Editors.XamComboEditor.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents) at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle) at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache) at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Editors.ValueEditor.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Editors.TextEditorBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Editors.XamComboEditor.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.FrameworkElement.UpdateStyleProperty() at System.Windows.TreeWalkHelper.InvalidateStyleAndReferences(DependencyObject d, ResourcesChangeInfo info, Boolean containsTypeOfKey) at System.Windows.TreeWalkHelper.OnResourcesChanged(DependencyObject d, ResourcesChangeInfo info, Boolean raiseResourceChangedEvent) at System.Windows.FrameworkElement.OnAncestorChangedInternal(TreeChangeInfo parentTreeState) at System.Windows.TreeWalkHelper.OnAncestorChanged(DependencyObject d, TreeChangeInfo info, Boolean visitedViaVisualTree) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at MS.Internal.PrePostDescendentsWalker`1._VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d, Boolean visitedViaVisualTree) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at MS.Internal.PrePostDescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation) at System.Windows.FrameworkElement.OnVisualParentChanged(DependencyObject oldParent) at System.Windows.Media.Visual.FireOnVisualParentChanged(DependencyObject oldParent) at System.Windows.Media.Visual.RemoveVisualChild(Visual child) at Infragistics.Windows.Virtualization.RecyclingItemsPanel.OnContainerDiscarded(Object sender, ContainerDiscardedEventArgs e) at Infragistics.Windows.Virtualization.RecyclingItemContainerGenerator.ProcessPendingReset()
Hello Andreas,
Thank you for your update on this matter.
I am curious if there is anything additional acting upon the XamComboEditor in the ComboBoxField in this case when the tabs are closed, or if there is any action whatsoever happening when the tabs are closed from your tab control? Can you please verify this?
Are you also providing your own styling to the EditorStyle of the ComboBoxField in this case, and if so, what is that Style setting? I know you mentioned that you are using the Office2013 theme, but I’m curious if there is an extension of that theme’s Styling potentially applied?
Hi AndrewWe're using the built-in .Net TabControl. There is not any Windows Forms component, host, or control involved. Just the idea of how the user works with our application, we took from the WinForms-MDI.I'll try to isolate the parts which are causing this issue and let you know.The strange thing is, that the use of this ComboBoxField used in a XamDataGrid on our Dashboard (first view the application present to the user), does not cause the issue. Only when it's used on this sub-object-view, deep down in the application.Regards
I am curious on point 3 in this case where you have described that you ported an MDI Windows Forms application in this case. Are you using a Windows Forms Host to include Windows-Forms controls, or are you using the built-in .NET TabControl/one of our Tab Controls for this?
Would it also be possible for you to share some of the markup you are using for the XamDataGrid in this case? Alternatively, if you have an isolated sample project that reliably reproduces this behavior, I will gladly take a look at that as well?
Hi AndrewThank you for looking into it.1. I tested It with version 21.2.20212.39 and 22.2.20222.19.2. Yes there is an inner exception. It's also logged, but there seems to be a little linebreak bug when building the log message. Therefore I also overlooked it. Sorry for that.The message is trailing on line 7:PresentationFramework Message: Beim Auswerten der Style-Eigenschaft für Element "Infragistics.Windows.Editors.XamComboEditor" wurde ein zyklischer Verweis gefunden.Sorry for the Geman, but it says something like:"Cyclic reference while evaluating style property"3. Actually it's not really a WPF window that get closed. We ported our MDI WinForm application and had to made a MDI like UI because our customer needed that, with a TabControl. So the grid is on a dynamically created tab page. Which gets removed from the TabItems collection and get sets to NULL.But with the inner exception, i have a starting point where to look at. But maybe you have more tipps? We use the Office2013 theme, loaded by the ThemeManager.Regards
I have been investigating into the behavior you are seeing just using a basic ComboBoxField, but at the moment I cannot seem to reproduce the behavior you are seeing. This leads me to believe that perhaps there is something specific about your scenario that could be causing this. I have a few questions for you that may help to narrow this down.
1. What is the specific version of Infragistics for WPF are you using?
2. Is there any sort of inner exception for the exception you are seeing? I can’t tell from the error message, but it looks like the exception you are receiving is a TargetInvocationException. Can you confirm this?
3. Is the grid within a dialog or is it a WPF Window that is closed to reproduce the issue? Is the drop-down open when you close the window to reproduce the issue?
Any additional information you can provide in this case may be helpful. If you have an isolated sample that demonstrates the behavior, that would be most helpful.
