1240
Exception in Infragistics.Windows.DataPresenter.RecordManager.OnBindingListChanged
We are getting a random ThrowArgumentOutOfRangeException in our application. Looking at the call stack, it is being caused in OnBindingListChanged which originates in OnDelayedChange. It appears that in OnBindingListChanged it is attempting to access an element in “list” without verifying the element is there. Unfortunately, we are unable to re-create this outside of our application. Is this something you are aware of and will be making changes to correct? The full call stack at the time of the exception is:
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at SD.LLBLGen.Pro.ORMSupportClasses.EntityViewBase`1.GetEntityAtIndex(Int32 index)
at SD.LLBLGen.Pro.ORMSupportClasses.EntityViewBase`1.System.Collections.IList.get_Item(Int32 index)
at Infragistics.Windows.DataPresenter.RecordManager.OnBindingListChanged(Object sender, ListChangedEventArgs e)
at Infragistics.Windows.DataPresenter.RecordManager.ProcessChangeNotification(Object sender, Object eventArgs)
at Infragistics.Windows.DataPresenter.RecordManager.ProcessQueuedChangeNotifications(Boolean calledFromDelayedChange)
at Infragistics.Windows.DataPresenter.RecordManager.OnDelayedChange()
Dan
