100
Current coordinate point position from mouse cursor
I am in need of  help trying to get the tooltip data from the mouse cursor when the tooltip is not enabled. I noticed that when the tooltip is enabled, the tooltip is set to an object called "ScatterSeriesValueDataContext" which has the X, Y and colorscale properties. But when the tooltip is disabled, the tooltip object is null so I cannot access "ScatterSeriesValueDataContext" anymore.
Is it possible to get the X, Y and colorscale coordinates from the mouse cursor when the tooltip is not enabled? The image below references the data I am trying to get to in code behind. I am trying to get this working with XamDataChart using ScatterAreaSeries
Thank you,
Gabriel
