280
Getting default labeltool foreground color
I have an issue setting the labeltool foreground color to its default (or set theme) value. I have a WPF application using lots of Infragistics components, applying the default theme on all Infragistics parts.
My main issue is how to find the correct brush in code behind in a value converter.
   public class PanelActiveConverter : IValueConverter
       public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
           if (value == null)
               return Binding.DoNothing;
           if (value is PanelListItem)
               var p = value as PanelListItem;
               if (p.Active == false)
                   return System.Windows.Media.Brushes.DarkRed;
               else
                   return System.Windows.Media.Brushes.Black;
           if (value is PanelData)
               var p = value as PanelData;
               else
       public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
I want to set the foreground brush of the control using this converter depending on the Active value. If false, I want it to be dark red, if not I want to use the default color for that control, wether it is the default theme or any set theme in the future.
All I can see so far, is that Infragistics applies a default theme and uses this on its control. How can I access this in code behind?
LabelTool is the primary control this applies to, but such as grid cell editor will also need the same type of handling.
Br
Fredrik Walka
